🚀 Elite CNC Deal of the Year: Unbeatable Price on a Elite CNC with Spindle & ATC! 🚀
Updated: Dec 3, 2024
DEAL EXPIRED
The Onefinity CNC Ultimate Elite Package with Spindle & ATC
Starting at $3837*USD
For a Limited time
Ultimate Elite Package includes:
  • Onefinity Elite CNC (model of choice)
  • Easy-Z Tool setter
  • Onefinity Redline Spindle (80mm)
  • Easy ATC
  • (QCW table not included)
Continuing to Reinvent the CNC Experience!
Onefinity changed the CNC experience, first by inventing the quick and easy set-up and pioneering linear rails and ball screws at a price makers and small businesses could afford. This forced many manufacturers to copy us and abandon their plastic wheels and rubber belts. We then revolutionized accessories for small shops with products like the Rolling - Folding Stand, Wall Mount and Use Anywhere QCW. Now, Onefinity is trailblazing affordable production CNC’s with our industry first EASY ATC Tool Changer, Advanced Rotary 4th Axis (not included), “Anti-Skip” Closed Loop Stepper Motors and the most reliable Spindle we’ve ever tested; our Onefinity REDLINE Spindle. Purchasing a CNC for your business has never been more affordable and reliable!
Watch the YouTube Video.
About the Elite Series Onefinity CNCs
The Onefinity Elite Series is one of the most advanced CNC lines on the market today. Featuring powerful “anti-skip,” closed loop stepper motors, “Z-20” heavy duty Z-slider, rigid, high precision, hardened steel linear motion shafts, a massive 15” touch display and one of the most advanced CNC controllers available. All this while maintaining our industry leading, user-friendly design with quick and simple set-up. No other CNC on the market can do what the Onefinity Elite Series can do!
Onefinity Elite Series Features:
  • Advanced, custom designed, Onefinity Masso Touch
  • Massive 15-inch high definition industrial capacitive touch LED screen
  • Rigid, high precision, hardened steel, linear motion Shafts
  • High speed, long travel, Z-20 heavy duty Z-Slider
  • Powerful “anti-skip,” closed loop stepper motors
  • Infrared homing sensors with auto squaring
  • Fast travel, precision ball screws on all axis
  • Conveniently located Emergency Stop
  • Plug and Play wiring supported by drag chains
  • WiFi enabled
  • Auto on/off router
  • Auto on/off Vacuum
  • Plug and play Tool Setter
  • Power Loss Recovery
  • Jump to Line
  • Continuous and incremental jogging via touch screen
  • Feed Rate Override - Adjust feed rate during a carve
  • Multiple Work offsets (G54-G59)
  • Micro Tramming
  • Quick and easy setup - start carving in under an hour
  • User friendly design
  • 7, 12 & 24 watt Laser (optional—plug and play)
  • Each unit fully production tested with a test carve to ensure proper functionality and quality
  • A large “how to” library with a very helpful and supportive community
  • Powerful Carveco Maker Advanced 3D Cad Software (1 year subscription)
  • ¼” Endmill
  • And much more…
Increased Speed, Now at 600 Inches Per Minute
When we first launched the Elite Series machines, we preset the rapids at 400 inches per minute to be conservative. The Onefinity Elite Series has always been capable of performing higher rapids and higher cutting speeds. The limiting factor has always been the router. With the addition of the Onefinity Spindle Kit by Redline Spindle you can unlock more of the Onefinity Elites potential. We have also improved the stepper resolution to produce incredibly smooth operation.
All Ultimate Package machines will ship with rapids of 600 inches per minute. No other CNC on the market can do what the Onefinity Elite Series can do!
(All Elite Series will now ship with the increased rapid settings of 600 IPM)
Onefinity REDLINE Spindle (Included)
Onefinity REDLINE Spindles are the most advanced Plug and Play Spindle Kits on the market today. Featuring a sleek and stylish patent pending design, compact all metal enclosure, a high quality custom made Spindle with four ceramic bearing standard and the only safety approved Plug and Play complete Spindle kit on the market today and much more….
No other Spindle Kit on the market has the quality, reliability and safety that the Onefinity REDLINE Spindle has!
Onefinity Spindle Kit by Redline CNC Features:
  • Ready to go safety approved, complete Spindle Kit
  • Compact custom designed all metal enclosure
  • Custom made, high quality Spindle with quadruple bearing supported shaft (available in 3 sizes)
  • Ceramic bearings standard on all Spindles
  • All wires and cables properly grounded and shielded
  • Detachable display with built-in manual over-ride switch
  • All power lines and electronics properly filtered and grounded
  • Sleek and stylish patent pending design
  • Quick and easy set-up. Plug and play
  • Three (3) great mounting options
  • Works with all Onefinity machines
  • And much more…
Onefinity Easy ATC (included)
Please note: The EASY ATC is an advanced accessory and may require some programming. We recommended this only for those familiar with using a CNC
The Onefinity Easy ATC is the most affordable and easiest way to add a reliable automatic tool changer to your Onefinity CNC. The Easy ATC features a sleek and stylish patent pending design, easy to load tool pockets, load and unload sensors and is designed to use with the Onefinity SM Dust Shoe to ensure your shop stays clean.
The Onefinity Easy ATC is the only Automatic Tool Changer on the market that allows you to use your existing collet Spindle to easily change tools automatically. In addition, the Easy ATC features Load and Unload sensors to help ensure your tool gets loaded properly. If a tool gets loaded incorrectly, the sensors will trigger an alarm and stop the CNC until the issue is corrected.
Onefinity Easy ATC Features:
  • Easy ATC with 4 Tool Holders
  • Patent Pending design
  • Four (4) high quality Spindle Collets
  • Load/Unload Sensors on each Tool Holder
  • Access to RapidChange ATC Tool loading software
  • Fully Supported by RapidChange ATC and Onefinity
  • All required wires and cables
  • Mount Anywhere Table Mounting Bracket (Optional)
  • Easy ATC QCW Mount for quick, easy, reliable installation (Optional)
  • And much more…
Get the Ultimate Elite Package today before time runs out. This is the lowest price it will ever be offered at!
Here is a breakdown of the key terms and conditions you agree to by placing an order for the Ultimate Elite Package, with a specific focus on the Onefinity Easy ATC tool changer: 1. Pre-order. You acknowledge the Onefinity Easy ATC is being pre-ordered and will be delivered to you separately from the Onefinity Elite CNC Machine, the Easy-Z Tool Setter, and the Onefinity Redline 80mm Spindle. 2. Delivery of the Onefinity Easy ATC: We anticipate we will begin receiving shipment of the Onefinity Easy ATC by February, 2025, and we expect to receive shipment of the Onefinity Easy ATC no later than April 30th, 2025. 3. Refund Policy: If, for any reason, we are unable to ship the Onefinity Easy ATC to you by April 30th, 2025, you will receive a full refund for the cost you paid in the pre-order of the Onefinity Easy ATC tool changer. 4. Price and Availability: The price and availability of the pre-ordered Onefinity Easy ATCs are subject to change. However, the price you paid at the time of preorder will be maintained. 5. Additional Terms: The purchase of the Ultimate Elite Package is subject to our general terms and conditions, which can be found on our website. In essence, this agreement outlines the expectations and protections for customers who order the Ultimate Elite Package, which includes a pre-order for the Onefinity Easy ATC. It ensures transparency about potential delays, guarantees a refund for the cost of the Onefinity Easy ATC tool changer if the delivery timeline is not met, and clarifies that the original pre-order price for the Onefinity Easy ATC will be maintained.
General Disclaimer: While Onefinity has made every effort at the time of publication to ensure the accuracy of the information provided herein, product specifications, configurations, system/component/options availability are all subject to change without notice. Product design specifications and colours are subject to change without notice and may vary from those shown. Errors and omissions excepted. Images displayed are for illustration purposes only. The images are intended to help illustrate the product and it’s functions and are not indicative of actual relative differences.
