Onefinity and AirWeights announce a new partnership. The ultimate vacuum table solution for your Onefinity CNC machines!
Updated: Aug 8, 2024
Today we're announcing a new partnership with AirWeights, a material hold down solution that requires no clamping, glue, or nails. AirWeights turns any CNC table into a powerful and modular vacuum work holding table, and will unleash new levels of capability and efficiency for your machine. AirWeights are compatible with ALL Onefinity machines, sizes, and series!
The AirWeights Story.
Made for Onefinity CNC, Made on Onefinity CNCs.
Did you know AirWeights are made on Onefinity machines? Check out the amazing story of the AirWeights journey from inception, to design, to product, to partnership with us in our video below!
REFINE YOUR WORKFLOW
Save Time & Money
The AirWeights system gains the user several efficiencies.
  • Saves time: You can secure multiple parts quickly
  • Cut down on material waste: No need to leave room on stock for screws or clamps.
  • Maximize table space: less clamps = more workspace
  • Repeatability: Refine your workflow and make your process more efficient
  • Reliability: Holding force is distributed evenly under your entire workpiece for a uniform and reliable hold
USING WHAT'S ALREADY THERE
The Weight of Air
It might not seem like it, but air is heavy! The pressure of the atmosphere above us pushes down with a force of almost 15lbs per square inch. To unlock that weight, you must create an area of low pressure below a mass, which AirWeights achieves in a compact, efficient, and affordable formfactor. The 24x24 AirWeights table can unleash nearly 8,000lbs of holding power at the flip of a switch!
AirWeights Features:
  1. Touch Plate Locating Port
  2. Quick Disconnect Fittings
  3. Locating Pin Holes (4)
  4. Pre-installed Perimeter Gasket
  5. Mounting Holes and Slots (12)
  6. Vacuum Ports (9)
  7. 1" Grid Pattern (customizable gasket layout)
AirWeights are available now!
Exclusive coupon code for Onefinity users!
To celebrate the launch of AirWeights with Onefinity CNC, we're offering an
exclusive coupon code for buyers through Onefinitycnc.com
of $50 off a 24x24 AirWeight System and $100 off a 24x48 AirWeight system!
(limited time only)
Use code "airweights24" to save big on 24x24!
and
Use code "airweights48" to save big on 24x48!
(promo code is case sensitive)
It gets even better! For a limited time,
AirWeights ships FREE in the lower 48 US!
There's never a better time purchase the ultimate clamping solution for your Onefinity CNC!
(limited time only) These deals only apply to www.onefinitycnc.com and do not apply to www.airweights.com.
Find AirWeights online:
Installing an AirWeights Vacuum Table On Your Onefinity CNC
Today's announcement is just the start of this epic partnership between Onefinity and AirWeights.
Many more innovative products are in the pipeline that will revolutionize your production and efficiency! Stay tuned!
Special notes:
 *This item is drop shipped directly from AirWeights.
Because this item is drop shipped directly from AirWeights in Colorado, USA, we are only able to offer these to customers in the lower 48 US states.  If you are outside of this region, please purchase through Airweights directly at www.airweights.com and they will accommodate shipping requests.
Purchases of this item with shipping to outside the lower 48 US states will have this item cancelled from your order.
314 views0 comments
