Introducing the Suckit SM Dust Shoe
The Suckit SM Dust Shoe mounts to the Spindle and moves with the Z axis. This allows the bristles to consistently surround the area being cut. This is especially effective while doing 3D carves or deep pockets. In addition, the Suckit SM has been specifically designed to work effectively with our EASY ATC!
Suckit SM (spindle mount) Dust Boot compatible with Onefinity ATC
What's included
What's included
Suckit SM Dust Shoe Includes:
  • Suckit SM Dust Shoe Top  section with pre-installed magnets and thumb Screw
  • Suckit SM Dust Shoe Bottom section with pre-installed magnets
  • 1x 30mm Long Brush Ring with pre-installed magnets
  • 1x 50mm Long Brush Ring with pre-installed magnets
  • All required hardware
The Suckit SM is extremely easy to install. Simply slide the Dust Shoe over the Spindle and tighten using the provided thumb screw.
Easy Bit Changing. The bottom section of the Suckit SM is easily removed to allow easy access to the bit and collet nut making bit changing a breeze.
Removable bottom for easy access to the bit
Removable Brush Ring. The Brush Ring is designed for easy removal, allowing you to quickly swap it out to adjust the brush length as needed. Plus, it can be removed even with the bit in place or lowered, making changes more convenient than ever!
Works with ATC
Works with ATC
Dust collection is a common challenge for most ATCs, and we understand how important it is. That’s why our engineering team collaborated closely with the RapidChange ATC team to develop the EASY ATC. After months of design and testing, we’re excited to introduce the Suckit SM—specifically designed to work seamlessly with the incredible EASY ATC!
Compatible with:
80mm Spindle ONLY.  Will not work with 65mm spindles or Makita router.
A Special Thank You!
THANK YOU!
THANK YOU!
We want to show our appreciation to the Onefinity community for investing in us for your cnc needs! As a special thank you, we will be including the Suckit SM Dust Boot FREE for all ATC orders placed before May 1st, 2025. This includes every ATC only order and every ultimate elite bundle orders in 2024. If your order is outstanding for the ATC, your getting one free! We know you've been waiting through our delays for the ATC, please know we are working very hard to ship these out!
There's no need to place a separate order or contact us—your free boot will be automatically included with your ATC purchase!
Please note: ATC orders placed after April 30, 2025 will not qualify for the free dust boot.
Note: Due to this free offer, the listing will appear as 'out of stock' until May 1st. This is to help prevent customers from accidentally purchasing a Suckit SM Dust Boot—only to later realize they're receiving one for free. Starting May 1st, the item will be available for purchase from the listing. (please note there will still be a lead time).
Free Adapter Files!
The Suckit SM Dust Boot comes standard with a 2.5 inch diameter port. Some users may want to use other diameter hoses, so we’ve released a few 3D files for those with 3d printers to print their own adapters.
Click the button to get the FREE files!
