Introducing "The Revolution" - Onefinity CNCs Rotary 4th Axis
- Nov 20, 2024
- 4 min read
Updated: Nov 21, 2024
One of the Most Advanced Rotary 4th Axis' on the Market Today.
Featuring ultra low backlash helical gear reducer for precise, quality carves. All metal construction to ensure quality and durability. 80mm, 4 jaw chuck with material adapter to allow for a variety of material shapes and sizes. Over 7 inch wide material can be machined up to
37- 1/4” long (Foreman version only). Plug and Play Three-Axis Touch Probe for quick and easy X, Y, Z location. Wall hanger for easy storage. Inductive Homing for auto angular alignment (Elite Only) and much more…. No other CNC on the market can do what the Onefinity can do!
Join the LIVE YouTube follow up video showing all things Revolution rotary! www.youtube.com/onefinitycnc.om
Re-inventing the CNC experience again!
Onefinity changed the CNC experience, first by standardizing a quick and easy set-up process and pioneering linear rails and ball screws at a price makers and small businesses could afford. This forced ALL manufacturers to abandon plastic wheels and rubber belts. We then revolutionized accessories for small shops with products like the Rolling - Folding Stand, Wall Mount and Use Anywhere QCW. Now, Onefinity is trailblazing again with the Revolution.
Onefinity Revolution - What you get:
Advanced custom designed Onefinity Revolution
Ultra low backlash Helical Gear reducer (No rubber Belts)
All Metal construction. No plastic or 3D printed parts
80mm, 4 jaw chuck
Over 7 inch diameter stock can be machined
Patent pending design allows for height adjustability
Plug and Play XYZ Probing for height and center line zeroing
Easy to store. Just unplug and hang on the wall
Inductive homing for auto Angular alignment
Quick and easy Setup. Start carving in under an hour
QCW Mount for fast, simple attachment
Hardened Steel, Linear motion shafts for quick, ridged, precise Tail Stock setup
Power Loss Recovery (Elite Only)
Built-in Laser centering Target
Jump to Line (Elite Only)
Anti-Skip Closed Loop Stepper motor (Elite Only)
Plug and play
A large “how to” library with a very helpful and supportive community
Powerful Carveco Maker with 4th axis support (if you purchased a Onefinity)
Each unit is fully production tested with a test carve to ensure proper functionality and quality
35mm Hardened steel tubes
Works with ALL Onefinity machines
True 4th Axis (Y Axis can move) unlike some competitors
48" Long option supports material up to 37"
32" Short option supports material up to 21"
And much more…
Ultra low backlash Helical Gear reducer - No Rubber Belts!
The Onefinity Revolution features an impressive high precision, ultra low backlash metal gearbox. The high precision internal helical gears are made using high quality materials, and hardened to allow high torque loads and long life. The quality of the Revolution is unmatched.
All Metal Design
One of the many benefits of the Onefinity Revolution is that it features an all metal design. You will not find any plastic or 3D printed parts on the Revolution. All hand nuts, Support ends, Gearbox mounts and Tail Stock parts are made from high strength aluminum. The Tail Stock Shaft and Tail Stock Adjusting Hand Nut is made from Stainless Steel. We are sure you will be impressed with the build quality and durability of the Onefinity Revolution!
Hardened Steel, Linear Motion Shafts
The Onefinity Revolution features Hardened Steel, Linear motion shafts for quick, ridged and precise Tail Stock set-up. In addition, all bearings are high load and feature effective seals for long life.
Unique Material Holding Adapter
The Onefinity Revolution comes with a unique material holding adapter to allow for the use of oversized material. The Material Holding Adapter allows for machining material that is too big for the jaws of the chuck to hold by themselves.
Create Precise, Stunning, High Quality Parts
The Onefinity Revolution allows you to create precision parts that are not only stunning but of exceptional quality!
Unique Height Adjusting Design
The Onefinity Revolution is the first and only Rotary 4th Axis that allows you to adjust the material loading height. This patent pending feature allows you to maximize your cutting material thickness height to match the gantry height of your CNC machine.
Tired of being stuck with a 4th Axis that can only handle small diameter parts and no way of increasing the material size it can handle? With the Onefinity Revolution there’s no need to worry, adjusting the height so you can increase the size of the material you can machine is now possible. You can go from accepting a 4” material size to a 7” material size (and beyond) by using Revolution Spacer Blocks.
Finding the exact center of your material is quick and easy with the built in Plug and Play XYZ Probe.
Inductive Homing
With the Onefinity Revolution not only can you easily find your material center with the XYZ Probe, you can easily find the angle of your work piece with the built-in inductive homing. (Elite Machines Only)
Innovative QCW Mount
The innovative patent pending QCW Mount allows the Revolution to be precision installed and ready to use within minutes. Your journey to 4th axis Carving couldn’t be easier.
Y-Axis Splitter Box (for non-elite machines)
To allow our non Elite customers to have true 4th axis function, we designed a unique Y-Axis Splitter Box. Simple plug your Y-Axis cables into the back of the Splitter box. They will stay there permanently. When you want to use your 4th Axis, simply plug it into the front and push the activate button. You now have true 4th axis motion (Y-Axis will now be able to move during a 4th axis carve).
The Y-Axis Splitter Box comes standard with all Pro/Original (BB Buildbotics) versions of the 4th axis.
Easy to use Clamping Brackets
The Revolutionary easy clamping brackets allow the Revolution to be installed virtually anywhere on your wasteboard.
Convenient Storage
When you are done using your REVOLUTION, simply unclamp it and hang it on the wall. It couldn’t be easier and more convenient!
The REVOLUTION is Available in Two (2) Sizes.
48" for Foreman and Journeyman machines.
32" for Woodworker sized machines.
*The Revolution is not available for Machinist (16") sized machines.
