Introducing AirWeights QCW Vacuum Slats - Complete Systems
Introducing the AirWeights QCW Vacuum Slats!
These AirWeights Vacuum Tables have a new form factor that mounts directly to the Onefinity Quick Change Wasteboard (QCW) Frame. Maximize available Z travel and continue to leverage the benefits of T-track with this fully integrated system.
Vacuum tables are a powerful tool on a CNC machine, offering dozens of advantages that benefit users of all levels. For the new user, a vacuum table is easy, forgiving, and a fast method to learn. For the production environment, a vacuum table offers efficient, reliable, and repeatable workholding.
Vacuum workholding removes the need for clamps, screws, tapes, or glues. You can secure your work to the table faster than ever, and there will be no obstacles in the way for your machine to run into. No more crashing your machine or breaking bits on clamps and screws!
With a total of 6 suction ports per Vacuum Slat, and a fully reconfigurable gasket grid, you can hold a variety of shapes, sizes, and quantities of work-material; making the system incredibly convenient and versatile. Combined with the included Spoilboards and Fixture Plates, you can also attain the most efficient and reliable workflows for batches and repeat runs. Each Vacuum Slat is an independent vacuum zone, allowing the operator complete control over where vacuum pressure is applied with the turn of a valve.
Our integrated manifold design makes AirWeights vacuum tables the most compact available, at just 0.8" thick. Our highly efficient vacuum pumps consume less energy, take up less space, and make less noise. Combining the two, AirWeights systems can provide an incredible 8,000lbs+ of holding power, instantly, at the flip of a switch. Our QCW Vacuum Slat Systems include everything you need to get started, and setup is straightforward. Each slat can be mounted to any secure from below QCW frame using screws from underneath. If your QCW frame is secure from above, remove the threaded inserts with a hole punch. The Vacuum Slats can then be easily mounted. Securing from beneath provides the maximum available surface area on the top side of these vacuum tables, a major performance advantage to this particular form factor.
AirWeights QCW Vacuum Slat Systems Include:
  • AirWeights QCW Vacuum Slats
  • Fixture Plates (1 per slat)
  • Spoilboards (1 per slat)
  • Grid Gasket Material
  • Mounting Screws
  • Locating Pins
  • Push-to-connect fittings and valves
  • Vacuum line
  • AirWeights Vacuum Pump
  • Remote control switch for pump operation
This is a pre-order item that will start shipping in Jan/Feb 2025
YouTube Live follow up with Jace from AirWeights to discuss the QCW Vacuum slats Monday, 18th at 9pm eastern!
Check out our other AirWeight Vacuum Tables!
1 Comment
I had the pleasure of using Ditch Witch Equipment and I must say, their customer service was top-notch. From the moment I reached out for assistance, their team was incredibly helpful and knowledgeable, guiding me through the entire process with ease, also find customer service contacts at ditch witch customer service. The equipment itself was a dream to use, with its user-friendly design and efficient performance. I was impressed by the durability and reliability of the Ditch Witch Equipment, making my project run smoothly and efficiently. I highly recommend Ditch Witch Equipment to anyone in need of reliable machinery and exceptional customer service.
Like
