Eazy-Z Tool Setter Settings Change (if it doesn't move down in Z when commanded)
Updated: Jan 23, 2024
Early settings of the Elite machines with Masso controller had default values of red/high. As of 2024, default settings from the factory are set to the corrected, Low/Green.
The Eazy-Z Tool Setter settings in the F1 page should be green/low. If yours is set to red/high, follow the steps below to adjust.
  • Go to the f1 page.
  • Leave the password blank.
  • Hit enter.
  • Scroll down in the center column.
  • Find Input 11 line labeled “tool setter”.
  • Single tap that line so that it is highlighted. Do not double tap the line.
  • Push the space bar to change it from red/high to green/low. Ensure it is green/low for correct operation.
  • Reboot the machine and try again.
861 views0 comments
